- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
svr500 it turns on registers hardisk recorder then nothing cant get anything on the remote the blue light flashing thats it help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
When you get a constant flashing light on the SVR-HDT500, what you need to do is press the reset switch and keep it held in for about 5 seconds, the light will slow down. Then switch it back on as normal. This switch is located at the front, under the USB flap. You do need a pen to press it in though.
Hope that helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Hope that helps
