headset control buttons not working
anilkumargupta
I used the headset that come as in-box accessories with xperia M2 dual but the single button on it is not working. Like for answering a call I tried press the button but nothing happen.
Is there any setting for that or is the headset button not working properly and should I replace it
Balises (1)
Hampus
Héros
I just tried this and it works fine for me. Could you boot your phone into safe mode and try to answer a call with your headset?
Otherwise, do you have the possibility to try another Sony headset to see if same thing happens?
9 RÉPONSES 9
profile.country.RO.title
_alexdon_
Do you have M2 or Z2?
alexdon
anilkumargupta
I have M2 dual
_alexdon_
Do you have smart key installed?
alexdon
anilkumargupta
No. will it solve my problem. Pls tell me about it
_alexdon_
I think @Hampus might assist better.
alexdon
Hampus
Héros
Hi,
Which headset was included for your Xperia M2 Dual? You should have a label attached to your headset with the model number.
anilkumargupta
AG-1100
Hampus
Héros
anilkumargupta
I tried it in safe mode and it works fine. The true caller application was preventing the function so I removed it .
Thanks for your help
