SD Card
SOLVED
csik
Visitor
SD Card
this phone drives me crazy - bought it a week ago - upgraded to latest firmware and troubles over troubles
html email .. see other thread
turn phone/display - yes works - but after some hours only vertical - no horizontal view possible - nedes restart !!! - this is not acceptable
sd card error - please format - card works fine on pc
walkman app - home screen - does not display all albums - what is it good for ?
for sure my last sony.....
19 REPLIES 19
csik
Visitor
problem clearly identified
its the sd card slot !
i removed the sd card after it to my surpise was working and copied a lot of stuff (music and photos from the former phone - a w595 - my wife love it) to the sd card using the adaptor (in this case a uhs card is very useful)
after returning it to the phone i was confronted with the message "card defect"
guess what - i removed the card and inserted it again - i did not count but i must had inserted it about 10 times before i got it workin again - this is very unusual
i could not believe that - so i removed the card - again i had to remove and insert it many times before it worked again
unfortunately sony does no longer have a representation in austria - instead they have servicepartners - i hope these guys are allowed to replace the phone - i fear that the card could lose connection in case of vibration or liitle bumps when putting it on a table - so i will insist to get it replaced - another way would be to get it replaced by the network provider i got it from
ps
the music left on the phone is for sure not drm protected - a drm protected iTunes file has a .m4p extension - my files where ripped from own  cds and have a .m4a extension
the swap tool does only move .mp3 files  to the sc card - with es file explorer i had no luck due to android restriction - the app is not allowed to write to external memory - the error message was something like "you need android 5 or root permission to copy files"
i dont understand this swap tool at all - after checking the boxes what  files should be exported to the sd card i can no longer change the settings - it seems that if you decide to have music pictures and videos on the sd card you can not switch back to have it in phone memory (in fact removing the sd card leads to a message -  sd crd removed - insert another one...)
profile.country.RO.title
_alexdon_
File commander is different from es explorer,it has access to write on external. But now what will happen? Will you be notified if they perform the repair?
alexdon
csik
Visitor
thanks for the hint with the preinstalled explorer !
i did not drop the phone for repair until now - i will call the sony service partner on monday if they will change the phone to another one or repair it
the phone is about 170-200 euros in shops - so i guess it is not worth more than 30 euros at all - its cheaper for sony to handle out a new one instead of repairing it
may be the better way is to insist that my provider should solve the problem with the phone because for legal reasons he is the first contact and is responsible for the product i bought from him
i will know better on monday
in case of having it repaired i wont accept it when it does not pass a test with 10 times remove - 10 times insert  without problems
i never had any contact problems with a phone
regards
manfred
_alexdon_
Anytime.In this case,I think you should contact your provider directly.
Keep us updated.
alexdon
csik
Visitor
just recognized your tolkien quotation and had to laugh Smiling_Face_with_open_mouth_&_closed_Eyes - i should no longer spend time on this cra..y phone....
just did a reboot because auto rotate freezed - and the sd card was again stated as "defect" - i did not touch the card til yesterday
so it seems to be rather an electrical mismatch than a contact problem
so who shall i blame - sandisc´s expensive card or the phone - you know the answer.....
and now i will follow tolkiens words ....
regards
manfred
_alexdon_
You are having quite a time with your device. After all,will you have it repaired or not?
alexdon
csik
Visitor
did some research on sandisk´s web site
to my surprise they dont recommend one of the newer fast cards - recommendation for m2 aqua is
http://pct1.sandisk.com/ProductList.aspx?DeviceID=21723
for my old arc s they recommend
http://pct1.sandisk.com/ProductList.aspx?DeviceID=17534  (this is the card that i bought for the aqua and this one works fine in the arc s)
so yesterday i ordered a new card (class 10 - no uhs specification) and if this one will not work too i will contact the service partner for austria and let them try to fix it / get another phone that works with sd card
if they cant solve that issue i can resign from my contract
regards
manfred
_alexdon_
Seems legit they have some recommendations but still, looks like extreme is over ultra and M2 aqua is newer than arc S. Strange.
alexdon
csik
Visitor
got my sandisk class 10 card (the type the link above) and this one works in the m2 aqua
regards
manfred
_alexdon_
Enjoy it.
alexdon
