Update issues with C1904
AAKN
Dear Support,
I am receiving the issues with updates on Xperia M - C1904.
After update, I am receiving the message "Unfortunately, the process android.process.media has stopped".
Please advice to resolve the issues.
Regards,
Arshi
AAKN
@ souvik7: I tried every step but failed. I tried using PC Companion for back but failed. Then tried updating through it but failed. Finally I formatted through mobile settings.
Anyway thanks to the Forum for providing the support.
Regards,
Arshi
10 RÉPONSES 10
Alexander1
Héros
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
 I would suggest that you first of all try to clear data for media storage under settings > apps>  all > clear data. Restart your phone and try again.
If the behavior still persists, I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
AAKN
Thank you for replying.
It seems that I am not able to follow your steps....
Once I click on Power Button, the window pops up..
now you had mentioned to follow "Now tap and hold the Power off option until you see this screen."
I had tried many times but SAFE Mode window is not appearing.
Kindly advice.
Regards,
Arshi
souvik87
Hi,
I am having the same problem. After updating it giving the same error. And I am not able to clear data for media storage.
Need help.
Thanking you,
Souvik
Alexander1
Héros
You can try to power off your phone. Wait a few seconds and start it again, once it have vibrate and beginning to boot, press and hold the volume down button and keep it pressed until the phone is started. This should enable safe mode.
AAKN
Dear Alexander,
Thank you for you prompt response.
Finally I was able to start the device in SAFE mode.....but the message is still appearing on the screen and preventing me to do any work.
The message is "Unfortunately, the process android.process.media has stopped."
Also I tried to connect through PC Companion to back up the data but the device is not getting detected.
Please advice.
Regards,
Arshi
souvik87
Hi Arshi,
Have you tried to clear data for media storage. After clearing this data my problem solved. I don't get the pop up saying "android.process.media has stopped"....
Alexander1
Héros
If clearing data as suggested above doesn't help I suggest that you repair the phone software using PC Companion:
http://www.sonymobile.com/update
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
AAKN
Regards,
Arshi
Alexander1
Héros
Glad that you find a solution for your problem.
