ajasmin
Visitor
xpiria m2 problem
i have problem when upgading my xspiria m2 upgrade is  interrupted, the phone can not to start, please help  what to do
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
You need to perform a system repair which will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
2 REPLIES 2
Thommo
ajasmin
Visitor
thanks you myyyy hero
