I bought a Sony Bravia TV, model number KDL2652010 around April 2006 in Belgium.
I am now planning to move back to the UK and would like to know if the TV will work in England? Can you please help or let me know who could help me.
Solved! Go to Solution.
Hi cazza1257 and welcome.
I presume you mean a KDL-26S2010?
If you look at the specifications in the manual here: -
http://pdf.crse.com/manuals/2684953111.pdf
it looks like it should work OK as the voltage is 220 to 240 volts AC @50Hz. It also has a DVB-T Tuner and has an English Menu option.
You will have to change the plug - it may be worth getting a Sony Service Agent to replace the entire mains cord with one with a UK plug.
Thank you so much for that, I am really happy that it will work in the UK. A friend had to sell his 5 TV's about 8 years ago when he left here, but I did hear that they are now compatible.
Caroline
