We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
I had this problem and I assume that you are using McAfee Security which blocks access to the camera when you try to set up the audio / visual settings. You need to uninstall the latest version of live messenger. Then go to Microsofts download website and download the 2008 version of messenger. I think that you find it will then work.
Good luck.
