vbs sript problem
profile.country.en_GB.title
africatwin2001
Visitor
vbs sript problem
Hi i bought a vio SVS13A1S9ES,after sometime the vio care had to be updated,after downloading the update,i have had problem with a notice vbs sript not found
7 REPLIES 7
rich912
Contributor
Hi africatwin2001,
Can you please let us know the full error message - is is the same as mentioned in this thread?
https://www.sony-europe.com/discussions/message/1304249#1304249
Rich
Go n-éirí an bóthar leat
africatwin2001
Visitor
Hi rich912 the message reads...cant find sript engine"VB script"for c\program data\sony corporation\vio care\del self patch.vbs.
africatwin2001
Visitor
rich912 i've tried to remove the vio care update ,but am uable to,as i need the administrater codes,also tried to remove the care pack,but the same text appears about the administration notice .After downloading the update a notice said the download  had failed,but it appears in the programs  updates list
Thanks for takeing the interest,i know i'm not the only person with the problem
Message was edited by: africatwin2001
rich912
Contributor
Hi africatwin2001,
Try running the CMD prompt with administrator privileges. To do this click Start > All Programs > Accessories > right click 'Command Prompt’– select ‘Run as Administrator’. Then type (or copy and paste) the following - schtasks.exe /Delete /TN "Sony Corporation\VAIO care\DelSelfPatch"
Rich
africatwin2001
Visitor
Hi rich912 tried the exe you sent me but a notice came up, invalid argument..is not recognised as an intrnal or external command operable program or batch file,thank's for takeing the time to write,if you have any more tip's i will try them . thanks
steve
rich912
Contributor
Hi africatwin2001,
Thanks for the feedback. This has been passed on to Support via the escalation of the main thread on this issue.
Please watch the above thread for any developements...
Rich
rich912
Contributor
Hi africatwin2001,
Support has responded as follows:
"Hi, Can you ask the customer to send us a screen shot of the CMD windows after the execution of the command. We need to check the results of the command.
So customer need to type the command while taking care of the spaces. Then press enter. Max the CMD Windows Take a screen shot Sent it to us Thanks in advance"
If you can please respond in this thread I will pass this on.
Also have you read the post from 'Wirixon' at the end of the following thread?
https://www.sony.co.uk/discussions/thread/173159?start=15&tstart=0
Rich
