Window 7 - Internet Explorer
SOLVED
profile.country.en_GB.title
clidawne
Visitor
I removed the IE blue icon from the on-screen drop-down menu in windows 7 and wish to re-install either in this or Pin it.
I cannot find the application anywhere in the Start menu and was hoping someone could point me in the right direction. I can see Google Chrome but would prefer Internet Explorer if possible.
1 ACCEPTED SOLUTION
Accepted Solutions
-frank-
Visitor
Hello clidawne,
You can locate the IE file if you go to My Computer > C Drive > Program Files > Internet Explorer.
The file is called "iexplore". You can then right click on it and select "Pin to Taskbar" or "Pin to Start Menu", depending on where you want it. You can also send it to the desktop.
I hope this helps.
Kind regards.
1 REPLY 1
-frank-
Visitor
Hello clidawne,
I hope this helps.
Kind regards.
