Hi,
in Germany it seems, that the Sony Xperia Z4 tablet has the model number SGP771.
I try to check, that the Sony Xperia Z4 works with our Bluetooth devices.
For this i want to check some Bluetooth parameters on https://www.bluetooth.org/tpg/listings.cfm
But the SGP771 is not known their. 😞
The "normal" support doesn´t can help me.
Is here anybody who knows the rigth model number of this product ?
Thanks.
Lutz
Solved! Go to Solution.
Thank you - but it isn´t.
Not SGP771 or SGP-771
I don´t know with wich number Sony declare the Bluetooth compatibility to the international Bluetooth organisation.
At normaly it should be the Model number - at other producers works it verry easy and well.
Thank you verry much ! ! !
Our necessary parameters are availabel - so our customers can choose Sony Xperia Z4 tablets - thank you !
