Solved! Go to Solution.
Yesterday I received a memory application update, was it related with this issue?
It cannot be a Android Wear thing because I change the phone and for me it works flowless since then , I have a LG G Watch R and S7. It is a Xperia X compact issue, before it, I had Z5 Compact and watch worked also without any BT problems. Also the watch was paird for 1 month to a Xperia Z3 with 5.1.1 and also worked flowless.
Hello everybody,
I have the same issue with BT connection.
BT connection to headsets needs about 30 seconds.
BT connection to smartwatch get lost after 1-2 hours.
What shall we do?
Hopefully it is not a hardware problem of the mobile. Is there any date available when sony wants to solve this issue?
Kind regards
(Please excuse my bad english)
It has been 48 hrs after upgrading to Nougat and no problems since that...
same in here...
yes, the problem is solved
I had to switch to other brand because of this.
