GPS signal not found
Elayne
Visitor
Hi,
Yesterday evening I changed GPS setup from the highest accuracy to "only GPS" and then back. Then the GPS didn't work at all. It doesn't work on Pokemon, Ingress, Google maps... There were no updates at the same time. I tried it on this morning and still the GPS is not working. The latest updates were after this GPS bug or 7day before it, so it seems that the applications are not the reason for that. I didn't drop the phone, only changed the setups.
I have booted the phone several times. I have removed some applications which use GPS and rebooted it again. I downloaded GPS Status & Toolbox and tried with that but it doesn't find GPS. And YES the location is on and the battery is charged so the reason is not with shutting down the GPS for battery saving.
Is the only way to fix this the factory reset? I don't want to do that >.<
1 REPLY 1
profile.country.NL.title
Strampke
The are two starting points in your search.
1) how is the situation in safe mode (excluding the influence of 3rd party apps)
2) test GPS in the support app on your phone.
And maybe the user guide has some clues too.
