Gibt es für das Xz3 noch die timeshift burst App? Wen ja wie öffne ich diese
Mfg
Is there still the timeshift burst App for the Xz3? Who, yes, how do I open these
Kind regards
gt
@Pad95first, please try and post in English. it's a global forum, and that way more people will be able to understand yo
there's no separate Timeshift Burst app anymore, but you can take burst shots by simply pressing and holding the on-screen shutter button. you can also make the physical button work the same way by opening camera settings and enabling "Burst with camera key" option.
@najodleglejszy wrote:you can also make the physical button work the same way by opening camera settings and enabling "Burst with camera key" option.
As for me, I tried using the physical button for "Burst mode" but disabled it as soon as realised that it creates a bunch of photos even if I try to create a single one.
@Ibnpetr wrote:As for me, I tried using the physical button for "Burst mode" but disabled it as soon as realised that it creates a bunch of photos even if I try to create a single one.
Same for me. Tried it but deactivated it again. When I use the physical shutter button I usually have gloves or something on my hand and then I can't feel when the button is pressed, resulting in a bunch of photos when I only wanted a single one
But burst mode with the on-screen button is fine, I sometimes use this.
Timeshift burst war eigentlich der beweggrund wieder zu Sony zurück zu gehen. Echt schade daß das xz3 nicht mehr hat 🙄
Timeshift burst was actually the motivation to go back to Sony again. It's a pity that the xz3 does not have more 🙄
gt
To clarify. The xz3 timeburst application has two way of working.
Select the ultra slow motion in parameter and you can make a 960fps slowdown when you press the red button.
Select the normal 120fps slowdown and you will get the timeburst function just like your old xz1.
Cheers.
