Battery drain
SOLVED
stexi
Visitor
Battery drain
Is it normal to drain 18% in 1 and a half hour with constantly use (radio, messenger, and 1-2 more apps) lowest brightness .. Im always thinking its draining too fast.. Am i wrong?
1 ACCEPTED SOLUTION
Accepted Solutions
CameronT
Champion
Hi @stexi
Based on how you mentioned you are using it, this does sound about right. Keep in mind that if your screen is constantly active, this will be the biggest drain on your battery. Couple that with audio and internet usage you will see roughly the drain you described here.
You can check what apps/functions are using the battery by going to Settings > Power Management > Battery usage.
4 REPLIES 4
CameronT
Champion
Hi @stexi
stexi
Visitor
Yea, the screen is most in use, 20% other apps only 5-6%. I am always trippin my phone is draining too fast dont know why so better if i ask 😄 thanks for help and sorry for bothering
CameronT
Champion
No bother at all @stexi it's what I'm here for Slightly_smiling_Face Feel free to ask anything here.
stexi
Visitor
Thanks one more time @CameronT
