Audio setting help needed
SOLVED
mrh2go1
Visitor
Please help me to solve the message attached below.  Z5 Premium.  Cannot access audio settings.  Receive the same in safe mode.  Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
mrh2go1
Visitor
I was able to resolve the problem by luck.  I had recently installed a bass booster app by Desaxed Studios.  I uninstalled this app and the problem was fixed.
Question - does anyone know of a good bass booster app that does not conflict?
Thanks for your help.
16 REPLIES 16
mrh2go1
Visitor
I have a Z5 Premium.  Need help to correct this problem.  When I click on Sound and Notification > audio settings, I get the following message;
This function is not available because some other sound effect application is active in higher priority.  To enable the function, go to Settings > Sound > Music effects and enable Audio settings.
Advise best way to correct this so audio settings are functional again.
Thank you.
Uliwooly
@mrh2go1
Do you have OK google enabled everywhere?
Phy
Legend
Legend
are you able to access the sound settings if you boot on safe mode?
Phy
Legend
Legend
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
mrh2go1
Visitor
Can you explain you reply below more clearly?  Thanks.
Also, same situation in safe mode.
Thanks again.
Uliwooly
@mrh2go1
Settings > language & input > google voice typing > OK Google detection > from any screen > turn it off
Uliwooly
@mrh2go1
don't create duplicate posts
mrh2go1
Visitor
Two points Uliwooly;
Google settings are OFF.
Same problem in safe mode.
Do you have other solutions??  Need your help, thanks.
Uliwooly
@mrh2go1
could you boot on safe mode and take a screenshot with the same message?
