Hi,
who knows how to change "my phone number" in my Xperia Z1 compact?
The current number is not mine, I want to change it.
I can see this phone number in settings: (actually my language is not english so the names in menu could vary because I'm translating them):
Settings => About phone => Common info => My phone number
Solved! Go to Solution.
If I'm not mistaken "my phone number" is actually a feature that reads what the SIM card provides as "my phone number".
As I understand its not possible to change this in the phone as default, but it may be possible in other phones or by using an application. Or perhaps you network operator can help you change this.
You could try and edit it from contacts-myself and set as default.
I think this supposed to be a right place to change "my phone number" but... I think I've got a bug in this feature.
I press "Edit" then I delete old phone number and add a new one, after that I tap "Done", but then old number still remains there. Only now it stands here as an additional, second number.
I can't get rid of it.
I even unlinked my google account from phonebook and turned off any sync. Also I rebooted my device, no result.
It seems that older SE could do that,Johan.And yes,the new ones just read the SIM.
I guess you're right. The whole thing is in my Sim-card, I'll try to figure out how to modify my number in sim.
Thank you guys for help!
Anytime.
Yes, as stated this can be modified on older SE phones. An Example would be the SE K850i where you would select Contacts > Options > More > Special Numbers > My Numbers. This is where your phone number is stored on your SIM. Once changed, it will show up in your Z1.
Some operators already have this number programmed in the SIM whereas others leave it blank.
I hope this helps.
Really helpful hints here; did the same myself with an old Sony Ericsson k800i: works a treat.
Address book: options: special numbers: edit; put in new number, swap SIM card back to Z1; job done!
Another way could be to get a SIM card adaptor off ebay - about £4 - and edit from a PC
Andy
