Solved! Go to Solution.
Boot in safe mode, does the same occur?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Try settings-apps-all,tap on 3 dots and reset app preferences.
Great news.
Strangely suddenly I cannot see the magnifying glass icon in the apps list so I don't know how to search for an app using name. How do I enable it there again?
So I booted into safe mode and then back to normal and yes the search bar is back there. BUT some things are a bit messed up now!
A lot of apps were invisible in the app list and there was this red SD card symbol. I checked in settings / storage and SD card was not detected. After about 2 minutes it appeared and the apps started to appear in app list too, BUT a lot of icons and widgets are missing on my main screens 😞 So it seems I will have to set it up again. And I had a resizable sticky notes widget with a bit of text in it which is gone now. Luckily it was not something too important...
I think those were your apps moved to SD.
But why was SD card unavailable for a few minutes? Of course I did not remove it during this.
