after iwas sleep i actived DND mode, i coulnt disabled it ' ive tried "end now"
use volume bottons even safe mode (long press on power botton)
the ringtone line stay gray, but hes move
notication and media okay
please help!
Solved! Go to Solution.
Hi @SuperMan1986, sorry to hear that.
One thing you can try is to create an automatic rule for Do not disturb. Set it to begin at a previous time and end a couple of minutes into the future and see if this will take your phone out of this mode.
An automatic rule can be created in Settings > Sound & notification > Do not disturb > Automatic rules > Add rule.
thanks! automatic rule worked!
That's great to hear!
My Phone every time priority only Mode. I cannot switch. I push Fast menu for close Priority only Mode. But ı cannot. Sorry for bad english pls help me
Sorry to hear that.
Did this start happening right now or has it been like this for a while? Are you able to disable Do not disturb if you reboot your phone to safe mode or is there no change then as well?
@Naessemaqlorarfeinie, your thread was merged with this one. Can you try what @Christofer, did this resolve what you are experiencing as well?
