Transferring Digital8 to DVD
billr.
Which  forum contains discussion on the above subject?. I have looked for an economical method to achieve this and I am surprised at the lack of information.
Is the only answer to used VRD-MC6, or maybe Vegas ?
profile.country.en_GB.title
Mick2011
Hi :slight_smile:
The simplest way is to use a Digital8 camcorder, connect that to a PC via firewire / i-Link, download the video and write to DVD using any basic video edtior.
Mick
5 RÉPONSES 5
Mick2011
Hi :slight_smile:
Mick
billr.
Thanks for the swift reply, I will try what you suggest.
Best wishes,
Bill
Mick2011
No worries Bill, let me know if you need any further help.
Mick
jchokker
Hi Mick:
I wonder if you can help me. I need to transfer movies on my sony handycam dcr-pc108e (with mini dv tapes) to my pc? Is this possible or do I need to record them to a dvd first?
Thanks in advance. Jimmy
Mick2011
Hi Jimmy, welcome to the Sony Forums :slight_smile:
It's the same exercise as Digital8 – no need to burn a DVD as the tape already contains digital data – you need to connect the camera's DV port to a firewire / i-Link port on your PC.
If you don't have the appropriate port on the PC, firewire cards are cheap enough and the cables readily available.
Mick
